07-31-2014 01:38 AM
Hi, I tried a lot to save and recall data I measured before.
The VI collects data and shows the actual measurements in XY graph 2. This works well.
Next step is to save this data and show it after the measurement is complete in graph 3.
I want to see all values measured before, but all I get is the first measurement.
Thanks in advance for any help!
07-31-2014 03:11 AM
I took the liberty to modify your VI to use tdms files instead of pure binary, I think it makes it much easier to achieve what you are doing.
the TDMS, I think, is great when you have multiple channels that you save by chunk because when you read, you can decide to read a whole channel.
I also implemented a way to stop all loops by simply clicking on stop.
If you have questions about what I did and why, don't hesitate to ask.
Hope this helps
Epictetus
07-31-2014 03:50 AM
Thanks a lot, this seems to work.
But in your version the the measurement restarts when the x value is about 6500.
I'm trying to figure out the reason.
07-31-2014 05:42 AM
I didn't see the problem in your solution.
So I added your code step by step in my old program and got it working.
I attached the new working version.
07-31-2014 05:46 AM
Great, did you get the point where a simple clic on stop will terminate all the loops?
Epictetus
07-31-2014 06:01 AM
yes, adding a "stop" to the queue is a great idea and is working fine!
