06-22-2010 02:01 PM
06-23-2010 08:37 AM
06-23-2010 02:46 PM
I woulod look at using a x-y plot and using a timestamp for the x-axis, then the you should have a common scale. Is that what you are looking for?
06-23-2010 02:52 PM
The Scale isn't the problem it is the size of the window. I just altered the "Chart History Length..." property and it seems to give the result I want. I am looking to see if I can alter this from a node in the code so I can change the history size based off the sampling rate
06-28-2010 05:22 PM
What happens when you set a larger min and max range?
