XY Graph Bugged? What am I missing?
I can't quite grasp why - after having done it many times - bundling two arrays to "feed" a XY graph isin't working. I have even indulged the puzzling error massage and built an array, which led to an even more puzzling error massage. See attached. Any clues as to what is going on?
(451 Views)
Hi Daniel,
The problem is: You don't use the graph's terminal, but a "Value" property node!
The terminal can adapt to any (allowed) datatype for the graph, but the property node does only accept the currently defined graph datatype: the datatype definition is done at the terminal…
(447 Views)
EDIT: too slow
(441 Views)
That's it. Thanks.
Oh well... monday.
(426 Views)
