XY Graph Property Nodes for Graph Pallette
I am currently using labview 2011, and my users are complaining that the Graph pallette is not very descriptive and they want boolean buttons to do the same things (mainly select area, pan, and show all).  Is there a property node to set these?  I do not want it to happen when the button is pressed, I want it to act just like the Graph Pallette and change the cursor so that you can do the action (except for show all of course).  Thanks.
Donald
(2,101 Views)
Hi dkennedy2010
I think that it should be possible using the property nodes, but I am not sure which properties are the ones that could do this, I will try to do it myself and I will let you know.
Regards
Esteban R.
(2,052 Views)
