acutator control
To do this everything should be in the same loop, and then you would use a case structure that checks your pot level. If the pot level is above 560, then output your digital line. So essentially it consists of three steps:
1) Continuous acquisition of pot level
2) Check pot level value
3) If pot level value larger than 560, write to digital output.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 21 of 23
(519 Views)
Hi will
Is it possible you set up a example VI?
of what you have in mind
Message 22 of 23
(509 Views)
You can take a look at this example from the NI Community. It's pretty close to what you're looking for.
http://decibel.ni.com/content/docs/DOC-8292
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
Message 23 of 23
(499 Views)
