adjust the space between text when printing
here is an exp:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 11 of 21
(1,110 Views)
For this
I would use a text indicator with black background and white text sized to as you like.
Ben
Message 12 of 21
(1,107 Views)
I tried that and It would not work
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 13 of 21
(1,104 Views)
Ben wrote:
For this
Ben
Ben,
can he do this with the report gen toolkit?
Message 14 of 21
(1,103 Views)
Harold,
Take a look at the attached VI.  You will have to use it as a subVI and wire the string values in, you will also have to setup the printing of the report.  It uses the function Append Front Panel Image To Report.vi to take an image of the front panel and use that as the report.  I have used this to do something similar to what you are doing in the past.  Play around with this and let me know how it works.  This VI is saved in 8.6.
Message Edited by jmcbee on 04-15-2009 03:05 PM
Message 15 of 21
(1,093 Views)
Here is a better version for you to try
Message 16 of 21
(1,086 Views)
the only problem is this is already a subvi lol, but i geuss it all works the same I will try this tomorrow and tell you how it goes
 also this is going on a label so I hope it fits
thanks,
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 17 of 21
(1,063 Views)
thanks,
if it doesnt fit just rearrange the front panel to make it fit, it is a what you see is what you get type of deal
Message 18 of 21
(1,045 Views)
I will give it a try
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 19 of 21
(1,031 Views)
well tried to make this work and it just would not print on my labels reconfigured the margins I reconfigured the layout and it still only printed a little black box and that was it.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 20 of 21
(1,018 Views)
