06-11-2010 12:05 PM
I created a program that sends data to a serial port and then recives new data. I send and recive data as ascii charicters however some of the ascii charicters I am reciving are not what they seem, my serial port monitor tells me that " “.... " equals " 93 00 00 00 1c " in hex. (it also says " 93 00 00 00 1d" is the same) how do i convice my serial reader vi to give me realevant data?
Solved! Go to Solution.
06-11-2010 12:17 PM
It looks like you use the old* Serial drivers. I suggest you move to the VISA system.
Is the Dumpview your program? Your diagram diagram does not show a write function or 'equals' function so I don't know how I can help you.
Ton
PS as in really old and might be obsolete once.
06-11-2010 12:59 PM
Im using lab view 6.1, I tried to use VISA but I cant find the COM3 port I'm using. No drop down menu appears when i place a VISA Resource Name control.
The dump view is from a serial port monitoring program (not labVIEW) and shows the output of my program as well as the responce from the divice I am sending info to.
Here are some examples of the problems I encounter.
06-11-2010 01:03 PM
06-11-2010 01:16 PM
I think that version of LV needed an entry in "Visaconf.ini" for it to show in the drop down list.
Is the number of bits set right?
Ben
06-11-2010 01:23 PM
So is the issue that LabVIEW is not reading the 1D and 1C, or is not writing them?
Note that 1D and 1C are field/file seperators
Ton
06-11-2010 01:39 PM
06-11-2010 01:49 PM
Try right-clciking on your indicator anc choose "slash codes" or "Hex".
Ben
06-11-2010 01:52 PM - edited 06-11-2010 01:53 PM
Where are you seeing the ".... ? That is what your dump program is displaying, and if you have the output of your serial read connected to a string indicator it may well show that as well, as the returned "numbers" (actually bytes) aren't displayable characters. If you do have a string indicator showing the returned data, have you "right clicked" on it and selected "hex display"?
I see Ben typed faster that I did!
06-11-2010 01:57 PM
LV_Pro wrote:...
Message Edited by LV_Pro on 06-11-2010 02:53 PM
Kudos to you Putnam for confirming my post before you saw it.
Ben
