cRIO, modbus, DECS and Micom Relays
I'm wanting to talk to DECS 200 and DECS 300 devices and also Micom relay devices. I will need Modbus to communicate with them. I understand I can use a cRIO as a slave, but is it possible to use a cRIO as a modbus master so I can request data from the devices?
Thanks in advance for any respones
(2,673 Views)
Accepted by topic author JChec
Hi JChec,
You can in fact set up the Modubus I/O server on a cRIO as either a Modbus master or Modbus slave. I am attaching a window here where you can see how these options are selected.
Message Edited by Eli_S on 04-15-2010 12:36 PM
Eli S.
(2,651 Views)
Hi Eli,
Thanks for the response and solution to my question. Appreciated
Jevon
(2,633 Views)
