can I programmatically control an xbox 360 console from a PC using a USB cable?
I don't believe that you will be able to solder to the pads themselves.
Go for the via's (through holes) just above and below the respective pads. You might need to clean away some solder resist from the PCB. You might consider practising on a similar circuit board before going for broke, if you have limited practical experience of soldering.
As an alternative you could just tape on a couple of wires with small copper pads or formed coils on the ends of them, a bit 'A Team' but less destructive to the controller perhaps?. My tip is to use that fabric gafa tape (SCOTCH brand). But watch out because it can get very sticky, if left on for a while. I wouldn't let the adhesive tape cover the other pads either but the rest of the cicruit board should have no problem with the adhesive. With this technique you should be able to recover the controller and work of some stress on Halo 3 Smiley Wink.
I shall watch with interest how you get on.
Good luck.
Message 11 of 15
(1,116 Views)
Good advice Conseils, thanks.
In fact I've attached a closeup of one such connection. I thought I had seen at least one example of soldering directly to the contacts as I had previously described but I have not been able to find it. It could have been a mechanical connection with hot glue holding it in place instead. I will definately however  use actual soldering points where I can find them.
Thanks again.
Message 12 of 15
(1,107 Views)
Looks OK, but test with a multimeter between the connection and that ground plane before powering up.
Many, many years ago I remember demonstrating in my haste, a circuit to my Father. Only to have bits of fluff floating around the living room after a small but loud pop. Bit of a problem with the Vero (strip) board, a capacitor and rushing in my excitement. I learnt a valable lesson that day! Smiley Tongue
Message 13 of 15
(1,095 Views)
Since this project is moving from concept to design I have decided to setup a web site so that I could record it all in one location. So, if anyone is interested in monitoring this project further you can follow the activity on my personal web site. I am not trying to drive traffic to this site but rather this is just a place to manage information related to various projects that I've been conducting.
Thanks to everyone for their assistance in getting me headed in he right direction and to NI for hosting this great site, and of course for the assistance I received from Elizabeth in technical support!
Bg's Project Pages
Message 14 of 15
(1,032 Views)
I want to provide an update to anyone who may be interested in how this project is progressing.
I've been on it for a while now and this weekend I will be hooking everything together for the initial shakedown of the primary components. I did the circuit board wiring last weekend (I appologize in advance for my shotty soldering skills 🙂 ) as well as the custom programming (command line C# program to run on the PC) required to drive the relay.
Conceptually it should all work so I'm pretty psyched to watch this thing in action! I'll continue to post updates on my personal web site.
Message 15 of 15
(986 Views)
