can i "decorate" my remote front panel?
can i "decorate" my remote front panel? Quote for example, adding some pics or links or changing the fonts or colours of fonts/background to make it more interesting like a website? If yes, what and how can i do?
(2,478 Views)
If you are using the default location for serving your remote panel, teh html page that gets generated will be saved in the "www" directory under your LabVIEW directory. (ie. C:\National Instruments\LabVIEW 7.1\www)
There should be a .htm file with the name of your VI or whatever you named it when you did the remote panel wizard. You can open this file and modify it to do whatever you want. Just make sure and not edit anything in the "OBJECT ID="LabVIEWControl"" tags.
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,478 Views)
