change background color of specific cell in array
I am trying to highlight the cell where the max value occurs in the attached VI.
Also, as a secondary feature, it it possible to change the background color of that specific cell?
hiNi
(5,462 Views)
Following examples could be useful:
Highlight Array Element
https://decibel.ni.com/content/docs/DOC-6327
Search 2D Array and Change Background of Individual Cells
https://decibel.ni.com/content/docs/DOC-15647
(5,454 Views)
I tried your example, but I have data that contains frequency (first column) and then amplitude (second column).  I would like to only highlight the ROW that contains the value of the amplitude above the set limit of -55.  In the attached VI, it will be only the last row.
Can you offer some suggestions as to how I can just get the row highlighted?
hiNi.
(5,391 Views)
Accepted by topic author hiNI
(5,374 Views)
THANK YOU!
(5,337 Views)
