clear arrays pragmatically
Thanks for that tip.
But my main question is how to dispose the inputs arrays just after these have been converted to images?
Message 11 of 30
(1,439 Views)
My main question, however, is how to dispose the input arrays once they have been converted into images?
Regards
Message 12 of 30
(1,435 Views)
I think you just wait for the subVI to finish executing.
Message 13 of 30
(1,434 Views)
Mmmm...That does not seem to work.
When I open my program, LabVIEW consumes about 150MB.
Once I have executed, LabVIEW consumes 1,2 GB.
All the arrays that were created as inputs of the different subVIs are stored. I would like to dispose them to solve this issue.
Message 14 of 30
(1,431 Views)
Are the subVI's front panels open when you run your program, or just the main VI?
Message 15 of 30
(1,426 Views)
Just the main one.
The problem was so bad at some point that I had to change the static calling of the SubVIs for dynamic.
Still, I have some issues with memory.
Message 16 of 30
(1,421 Views)
You're not doing somethilg silly like loading the image and then making that a local variable every time to each SubVI, are you?
Message 17 of 30
(1,413 Views)
Can you try putting the Request Deallocation Function on your SubVI with a True constant wired to it and see if that helps?
Message 18 of 30
(1,401 Views)
Nope. I'm not using local variables.
Already using request memory deallocation without solving the problem.
Message 19 of 30
(1,396 Views)
Are you running the subVIs in parallel, causing the arrays to stack up memory at the same time? If you run the subVIs in series, then they should each allocate and release memory before/after the other subVIs run.
You said "just the main" VI's Front Panel is open. So why can't you make the subVIs inline to ignore that memory allocation required of displaying on the front panel?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 20 of 30
(1,374 Views)
