client server..How do I do so that the client takes the control of the system?
therealdeal wrote:
My god...it's very difficult for me..I see network queue Smiley Sad
If you can use a native LabVIEW queue then the network queues are essentially the same. You don't have to modify the low level code you simply use them as is. When using a client/server model it is always best to use some type of messaging scheme. Otherwise how will you know how much data you should read.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 16
(863 Views)
ok but I'm a little practical of labview...Smiley Sad
Message 12 of 16
(853 Views)
I don't know how it used..Smiley Sad
Message 13 of 16
(849 Views)
This won't solve your immediate problems but I suggest that you consider taking LabVIEW Basics I & II. In addition, you can work through the online tutorials. It sounds like you need to learn the basics before you dive in to the more complex topics.
Mark Yedinak
LabVIEW Champion
Message 14 of 16
(843 Views)
thanks..but can I use this example?
http://zone.ni.com/devzone/cda/tut/p/id/3055
Message 15 of 16
(832 Views)
Yes you can but you would still benefit quite a bit from taking some time to understand the basics before working on more complax stuff.
Mark Yedinak
LabVIEW Champion
Message 16 of 16
(816 Views)
