clubbing different output values to one array
hi,
   In the vi i am working i get 3 output values from different frames in the same vi, i want to have all these values in a single array, can i do it
(2,571 Views)
You can use the "build array" primitive.
See this:
Hope this helps
Epictetus
Antoine Chalons
(2,569 Views)
hi,
   I get 2 output values from each frame. I get 3 outputs in the similar way. I need to club all these values in a single array. How can i split the values from each output.
(2,566 Views)
Sorry I don't understand what you mean... can you post your VI or a screenshot of the diagram please?
Epictetus
Antoine Chalons
(2,562 Views)
hi,
     I have attached my vi just have a look at it
(2,556 Views)
Hi Samineni,
in the picture TiTou posted you see the BuildArray funciton marked. Just above that you see the IndexArray function. Now you should use the context help...
It seems you should learn the basics! And then get rid of the sequence structure:
(2,554 Views)
nothing is clear from your vi.
 you would like a for loop in place of outer while loop.
you can use error cluster to inforce dataflow instead of seqence str.
these are general suggestions....
(2,550 Views)
