colour change to buttons
         I have a series of buttons placed side by side. I'm changing focus from one button to another using navigation keys. Now the problem is the focus is not clearly visible. Is there any option to do it?
         I got some idea of using colour change option, when focus is on one button change its colour to some specific colour and rest to some other specific colour. But i'm not able to implement it clearly. so please give me some idea..
Thanking you,
sushmith
Thanking you,
Sushmith
(4,063 Views)
Maybe you can use property nodes to see if a button is on focus. I'm not able to check it now, but I think that Key Focus (property) does this job.
Then, create an architecture that see which button is on focus. Write the new colors to this button (also using property nodes, but I don't remember any now).
This isn't the solution, but as you asked, it's an idea.
Regards and good luck.
Mondoni
(4,039 Views)
Accepted by topic author sushmith_ks
If you want to change the color of a button, you have to watch out which type of button you're using.  Not all buttons can have their colort changed.
If youre looking for a professional look, you don't want to make a colorbook either by changing every button into another color.
What you can do is putting behind each button an LED indicator which is slightly bigger then the button itself.
When the button have the focus, set that indicator to true.  And it will light up.
It's a bit more work, but it look so much nicer.
Personally I don't like to mess with colors.  I love simplicity.  Thats why I use systembuttons, which have a blue surface already when they have focus
Hope this helps
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,032 Views)
yes...definitely do not make it look like a "coloring book" Smiley Mad . I would use the disabled property nodes....
(4,018 Views)
You can use the KeyFocus property with the Object Highlight method to temporarily highlight the control that has the focus. See the attached exemple, use the Tab key to switch focus (LV2012).
Ben64
(3,988 Views)
Try something like this.
(3,987 Views)
Unfortunately blinking doesn't work well with some type of controls like numeric and string because you need to click the enter key before they start blinking.
Note: Your use of char = 9 is a good thing, there is no need to check focus for every key pressed.
Ben64
(3,982 Views)
