comment puis-je récupérer une image à partir d'un fichier html ?
Hi everyone,
I want to read an html file and use it later, however I can't get the image from it, but I only get the text.
However, in the html and open file functions, there are only functions to create an html page and not to parse and dissect it. Is there a way to do this?
or a way to recover the image?
Thank you all.
O.
(739 Views)
Hi CO2022
Are you using LabVIEW to get the image from HTML file?
If yes, then try to use Get Image Method - NI in LabVIEW to achieve your desaired results.
Regards)
(519 Views)
