My CompactRIO development PC has fallen over, with the message
The plug-in for the selcted item is not installed on your system. It appears I've lost the C-Module support for the 4 modules pluged into my crio-9103 chassis. My first attempt at recovery was to select the repair option in add/remove software to repair LabVIEW 8.2, then RIO21, then patch RIO210f1, as per instructions
ftp://ftp.ni.com/support/fpga/ni-rio/2.1.0f1/readme.html
I've also noticed CompactRIO remains missing from MAX, even after repeating the installations of the above. Next, I figure I should try a complete un-install of everything, followed by a complete re-install, but I'm desperate for a quicker fix if anyone can help? I'm also keep to figure out what has caused the problem, I have LV6.1, LV7.0, LV7.1 & LV8.2 installed on the PC, the error occured after I opened some older code in LV8.2 that had broken links to the analysis dll (Ivanlys.dll).
