12-09-2008 01:52 PM
hi there everyone,
can someone please help me.
i already created this subvi.
it is already doing what i wanted.
it is the only way i know how to do it.
BUT...
i need another way to do this before i have a new system. i will have to modify the code. i just want to modify a text file if possible. its easier to document rather than changing the code.
here is what i have..
Solved! Go to Solution.
12-09-2008 01:58 PM
Hi krispikream, you are missing a subvi. I am not sure I understand your question. It looks to me like the vi you attached is not fully wired, but you say that it works. I am guessing that you have to modify it because of all the hard wired constants in your case structures? What do these constants represent? What text file are you talking about modifying?
12-09-2008 02:07 PM
I would put all the Computer Names and Test System Names in arrays. Search the Computer Names Array using Search 1D array and set the ring value to the index that comes out of the search. You can load both names from a text file and set the ring Strings Property from the array of Test System Names. However, you will have to constantly do this throughout the code where you want to display the ring.
Since you didn't really tell us what you are doing in the grand scheme of things, you may just want to take the text file and save the 2 arrays into a LV2 style global. This way whenever you need the Test System value, you search the Computer Names array for the matching Computer Name, then index the Test System Names to get the Test System string.
12-09-2008 02:07 PM
ok..ignore the subvi..
the bottom of my code is where i am working with new code...
the top portion is the current code i have...
can you run it with what i have.. and see how it does..
basically. it read from the computer the name of the system. if test sytem = xxxxxxx then this is equal to test system...
i want to implement the same routine, but not using the same code...
i want to read from a text file. and not from String to ip o ip to string.
12-09-2008 02:08 PM
12-09-2008 02:15 PM
okay...
start at test..
user select test system...i currently have 4. i dont want that..i want labview to select the system...
so i created the code above...
if ip to string = system1, then testsequence = 1...something like that...
that is the problem..right now i have 4 system...if i more systems in the future. We will have to write new requirements..
so maybe its best that i create text file.
read from text file and determine what system it is..
knowing what system is what will move on to the setting up of the system and that's already taken care of with other subvi..
test sequence control is needed on the next subvi...
12-09-2008 02:22 PM
If you just want to put the System Name in the text file, then create a simple text file in Notepad which has the ID. Then use Read Characters from File on the File pallette to get the text string. You then have your System ID.
12-09-2008 02:30 PM - edited 12-09-2008 02:30 PM
12-09-2008 02:35 PM
12-09-2008 02:36 PM - edited 12-09-2008 02:37 PM
Instead of using the TestStationID bit on the bottom just use one of these
like before to compare the active PC to the list of available PC's.
