03-27-2014 11:51 AM
Hi guys,
I know for sure that If you have a vi done in Lbw11 it is possible to be opened in Lbw13 but the question is if I create a new vi in Lb13 using the new features those new features will be seen without any problems in Lbw 11??
Thank you
03-27-2014 11:57 AM
03-27-2014 11:58 AM
yep 🙂
03-27-2014 12:05 PM
LV is the typical abbreviation for LabVIEW.
If you use a new feature, it will be translated when you perform a downconvert. LabVIEW 2011 does not know any of the features of 2013. So it will be different.
03-28-2014 02:53 AM
OK
Thanks a lot! 🙂
03-28-2014 03:04 AM
Some down convert will attempt to actually replace a certain new feature with similar functioning code in the older version, if that is not to complicated to do, but in general anything really new in a LabVIEW version will simply be replaced by a graphic box with a small label on it and therefore usually result in broken code.
