11-08-2010 10:23 PM
Tanya's suggestion of "Extending 32 bit memory"
worked for me compiling a big project with LV2010 32bit on Win 7 32 bit
thanks
michael
12-14-2010 09:50 AM
Congratulations, Michael, that compiling even big projects succeeds.
In my case it's still a pitty: a relatively small(!) project consumes a huge amount of memory. Which for shure issn't necessary since it compiles well with older LabView version.
I'd love to hear something from NI about how to track *what* usese this much memory, after that we could then continue discussion....
Have a good time!
12-16-2010 06:01 PM
Hi loetknecht and everyone,
I just wanted to post a link to a KnowledgeBase article that discusses this issue. Take a look at the following article for some explanation of the issue and potential workarounds:
LabVIEW Compiler Memory Usage and Performance
I apologize for any inconveniences the changes to our compiler has caused and hopefully the workarounds will work for you.
Aaron P
02-01-2011 09:35 PM
Hello, I had the same error in XP and this fixed it but I got windows 7 and the article does not say how to do it in windows 7. Does anybody knows?
02-02-2011 03:04 PM
It works now. Windows Vista solution works for Windows 7
06-23-2011 05:50 AM
Dear All,
I have face the same problem, my code works well in previous version (2009) but in 2010 it will get compile error.
I have also increase my virtual memory size up to 4 GB as shown in fig. (Virtual Memory). but it not works.
When I am increase my virtual memroy from boot.ini file, as posted earlier, I got a problem with functionality of my operating system.
Is there any other solution, which help me out to run my code.
06-24-2011 01:26 PM
Paarth,
Where you able to look at those articles on optimizing the compiler?
They are here too:
http://digital.ni.com/public.nsf/websearch/BA4B9038D01F3C99862577CA004BE1AD?OpenDocument
http://digital.ni.com/public.nsf/websearch/3A28C7098620AFD78625783400763C69?OpenDocument
Short of chaning the compiler and making the boot 4 GB you may need to actually change the code to make it either smaller, more effiecient, or less processing intensive.
I hope those links help 🙂
06-29-2011 01:37 AM - edited 06-29-2011 01:41 AM
Sam,
Thanks for giving me another solution.
It's Work.
I've replace LabVIEW 2010 with LabVIEW 2010 SP1
Paarth
