connecting arduino and visa with labview
hello, my name is angga and i am working my final project.
i want to controlling a heater with pwm that read from thermocouple,
i am using arduino mega 2560 board, max6675, thermocouple type k, solid state relay and heater.
at first i made a program that can read temperature and produce pwm signal using thermistor, as thermistor sub vi already made an example in labview so it can be use instantly. but now, as my needs to controlling a higher temperature, i must change the sensor to thermocouple.
I already got the arduino code for max6675.
I already made visa for reading arduino trough labVIEW, but i still confuse how to make it pwm as an output
I already made arduino program in labVIEW to produce pwm signal but it still reading with thermistor
is there any way to make "TempMon2.vi" unite with "Thermistor read connect to lamp.vi" as teh "TempMon2.vi" replacing thermistor that attach in "Thermistor read connect to lamp.vi" program ?
i hope somebody can help me, i'm so desperate 😞
thanks in advance
here is the arduino program that i use
#include <max6675.h>
#include <Wire.h>
int thermoSO = A1;
int thermoCS = A2;
int thermoCSK = A3;
MAX6675 thermocouple(thermoCSK,thermoCS,thermoSO);
int vccPin = A0;
int gndPin =A4;
void setup() {
Serial.begin(9600);
//use Arduino pins
pinMode(vccPin,OUTPUT);digitalWrite(vccPin,HIGH);
pinMode(gndPin,OUTPUT);digitalWrite(gndPin, LOW);
//Serial.println("MAX6675 test");
//wait for MAX chip to stabilize
delay(500);
void loop() {
//basic readout test, just print the current temp
//serial.print("C=");
int temp = thermocouple.readCelsius();
Serial.println(temp);
//Serial.print("F+");
//Serial.println(thermocouple.readFahrenheit());
delay(500);
(3,356 Views)
Hello Angs, please do not create multiple threads for the same issue, it only fragments our ability to help, stick to a single thread so we can all be in the same channel. Unless you specifically require to use VISA primitives, I would advice to just stick to the LIFA ready-made functions, they're very well made and realiable. Please stick to your most recent thread (where you asked specifically about the thermocouple) from now on, thanks.
(3,326 Views)
And just to be thorough, here is a link to that thread: how to switching arduino thermistor with visa temperature read?
GCentral
(3,314 Views)
