consumer producer event control button top VI
I am trying to control the main.vi example that create the “create project wizard” called “Continuous Measurement and logging” from a top lever VI.
The problem I have is that, I will not start the main.vi unless it’s done by an event created by an operator. How can I control programmatically those buttons from another VI?
I am attaching the block diagram picture from the wizard and the simple top_level VI to control that VI. Thanks
(2,240 Views)
That main VI is meant to act as a top level VI.  It is recommended you add on to that VI if you need more capability.
GCentral
(2,226 Views)
