data acquisition and process in FPGA
Hi!
In FPGA, I'm trying to acquire analog data (0~10V) with a specific time clock which is rising edge of each digital pulse from encoder.
I made the part of getting data on rising edge, but I don't know how to store  i th and i+1 th data.
(Data Frequency is about less than 250kHz)
I have cRIO-9074, NI 9411(encoder), NI 9205(AI module),
data
  1st  data , 2nd data,  3rd data,   4th 5th 6th 7th .....  i -1 th ,  i th ,  i+1 th....  1200 th  (Approximately)
I need every sum of two consecutive data such as   1st + 2nd ,  2nd +3rd , 3rd+4th data, .... i-1 th + i th ,   i th + (i +1 th)  .... 1199 th + 1200 th  (Approximately)
On the process of two consecutive sum,
 [ i-1 th  +  i th ] / [a value]  +  [ the other i th value from different data acquistion ]  = 1199 data set    (until 1200 th data)
and then
all the data in the data set (1199 data) will be a total value.
Thank you so much!
All advices are welcome!
Sincerely,
Hyo
(2,882 Views)
Hi.
Use Shift Registers to store the last value. After you can sum it with the next value in the next iteration.
Best Regards,
Edgar Shadyan.
(2,855 Views)
Accepted by topic author catalysthw
Sounds like a simple Feedback Node will do the trick.
GCentral
(2,824 Views)
