exit of queued state machine
A solution i've used, that i saw in some program, was to simply release the queue to cause a queue error. My producer/consumer then loops until error which makes them stop. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 22
(520 Views)
Hello PJS,
last day I read digramme to quick,
Yes i see, now events and case are in the same loop. multiple is a way of excuting paralele state i suppose.
So i suppose event strucutre is scrutinized via a polling mode( is the work of Queue manager ?), i have some pain to understand
this executing mode, but if you tell it works well, i really want to trust you
Sorry to insist but have you in your library , a 'school' example to ilustrate your base state machine
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 22 of 22
(484 Views)
