05-24-2023 03:14 PM
Thanks, I am a little new to LabView and it wanting a 2D array always was strange if my data was only 1D. I was also using insert to array which was making a row of zeros after the data. I use "Replace Array Subset now" or will build it with correct structure.
Adepta
05-26-2023 08:49 PM
I'm not sure what you are doing, but you should only use "Build Array", not "Insert to Array" or "Replace Array Subset".
Let me try to explain. Suppose I have a number, say "4". I open a Block Diagram, drop down a "Numeric Constant" from the Numeric Palette, change the "0" to a "4", and what do I have? An I32 number, right?
Now I right-click this, and say "Change to Array". LabVIEW draws an "Array Box" around it, and shows the 4 is sitting at offset 0. If I attach a Wire to this Array, it is the slightly-thicker Blue Wire of a 1D Array. If I connect this 1D Array to the Array Size function, it will return me an I32 that shows the value "1" when I run the code. Note that you have to make sure that there's a value in the Array (otherwise it will be an "Empty Array" and have a size of 0).
Now drag down on the Array Index box on the left to make a 2D Array. Note the "Wire" from the Array to the Array Size function shows 2 parallel blue lines (for a 2D Array), and the "scalar" thin wire from Array Size to the (scalar) indicator is broken. Delete the Indicator and wire, right-click the output of the Array Size function, and note that it creates a 1D Array to hold the (now 2) dimensions. Run the program again. It shows you that your one numeric value, "4", is now the single element in a 2D Array of 1 row and 1 column.
In your case, you have a 1D Array of data, say of 100 elements. If you pass it through "Build Array", you will get a 2D Array of 1 Row and 100 columns, which will be written as (... you guessed it ...) a single row of 100 columns.
LabVIEW cleverly figured out that you wanted to send only 1 row, so it outputs 1 row. It doesn't need to allocate any more memory for an "empty extra row". Trust me, I do this with Easy Table all the time.
