03-16-2014 11:08 AM
I've only done very slow data acquisition with LabVIEW, and I was wondering what's the fastest (conservatively fastest I'm not trying to push the limits) data acqusition and data logging that is possible on a compact DAQ device? and is the benifit of moving over to a cRIO from a cDAQ really just for more realiable speed and data acquisition? I'm interested in about 30kS/s over 5 analog input channels.
much thanks!
Solved! Go to Solution.
03-16-2014 11:45 AM
03-16-2014 05:49 PM
Hi, the rest of the program won't be doing much, 4-20mA open loop control to a motor or something, nothign fancy.
I remember hearing that a Windows machine can only give you about 1ms loop time iteration, due to it not being a real time operating system. I thought that this meant you could only sample at 1ms (1khz) continuously. I've never had to sample at anything above a few Hz so I never explored this... I'm thinking that I'm off on how I'm interpreting this stuff.... if I have a compact DAQ how can I find out how fast I can continuously and realiably sample and log data? Is there a good link or something on the NI site I can read about this? I've been looking for something.
thanks!
03-16-2014 06:52 PM
03-16-2014 07:34 PM
Yes I was just accquiring a sample every iteration
so these rates of 250kS/s are achievable with a regular windows computer? I'm guessing just grabbing a bunch at a time and then during the loop iteration (which would be the slow part) take these 250,000 samples and write them to a TDMS file or something.... I guess keeping them in some buffer or FIFO or something?
At what point would you say, ok this is too fast I need to switch over to an FPGA cRIO solution... would 500kS/s or something like that be the cutoff point where you need a real time OS?
thanks!
03-16-2014 08:10 PM
