12-31-2012 10:24 AM
please help, i hv a text file with three columns of integer values. I need to take 500 values in each column and replace them with their average.
Solved! Go to Solution.
12-31-2012 11:37 AM
All your posts are the same thing. You provide a file and a task and then say "Please help" but you never actually show that you've at least tried to do your own work.
Post your attempt at this task an you'll get better assistance...
12-31-2012 12:00 PM
i did it
12-31-2012 12:12 PM
Congratulations! I'm still stuck with LabVIEW 2010 so I can't open your code. Have you tested it?
12-31-2012 09:55 PM
A lof if this could probably be simplified. Here are some ideas.... Many thing could be improved even more.
01-01-2013 07:35 AM
@Niquist: i have only labview 2011 to use friend, the code is working.
Thanks for the reply
01-01-2013 07:36 AM
@altenbach : thanks a lot for the reply and code, i shall try it soon as i get to my computer with labview installed.
Thanks a lot.
01-01-2013 08:41 AM
@altenbach :the code u gave is really clever, thanks a lot 🙂
