gain and phase margins from simulation data
Dear forum members,
Is it possible to display the Gain and Phase Margins from a Control and Simulation Loop ?
I have a simple SISO control loop (P+I controller) and this is subject to a unit step input.  I can display the output response graph via a Collector but cannot figure out how to display the Gain and Phase Margins from within the Control and Simulation Loop.
I note that there is a CD Gain and Phase Margin.vi that looks like what I need since it provides Gain and Phase Margin output however I cannot figure out how to interconnect this vi to what I have in the Control and Simulation Loop.
If anyone can assist or provide guidance it would be appreciated.
(3,160 Views)
Hi bunnykins,
 Please find the necessary help from this link:
 http://zone.ni.com/reference/en-XX/help/370853D-01/lvctrldsgn/gain_and_phase_margin/..
 Generally cntrl-H will give the context-help of any labview function.
  Even you can see the examples of how Gain and Phase margins are plotted.
SrikrishnaNF
Srikrishna
(3,151 Views)
I'm already aware of the CD Gain and Phase Margin.vi and have already read what you have sent as a link before I posted the original post (I did point this out in my orginal post!!).  The problem I have is "How to use this CD Gain and Phase Margin.vi with the Control and Simulation frame" ?  I cannot link this function since the signals are mismatched.  I also do not see any similar function within the Simulation set of functions.
I guess that I need to somehow extract the closed-loop transfer function from the Simulation frame before being able to use the CD Gain and Phase Margin.vi since this function requires a transfer function model as its input (assuming that its a TF input selected).  If anyone knows how to do this I'd appreciate some advice.
(3,143 Views)
Is your simulation linear or nonlinear ? You mention it is has a PI controller (linear without saturation / anti-windup), but not the simulated process being controlled.
Gain and phase margin work on linear *models*, not on the data that a simulation loop produces.
If you have a nonlinear model it will need to be linearised about an operating point first.
Remember - use the open loop system (control and process) to calculate the gain and phase margin, but they give the stability of the closed loop system.
This looks like a good reference if you need more info / examples:
http://www.ni.com/white-paper/6450/en
Consultant Control Engineer
www-isc-ltd.com
(3,136 Views)
