01-10-2010 11:21 AM
Hello
well how can I make a sound clip using labview where a boolean variable is the control so that when the boulean is true the sound is not going to repeat it self
merci
01-10-2010 02:35 PM
01-10-2010 03:27 PM
Look at the functions on the Graphics & Sound>Sound>Sound Output palette.
When you pop up the function palette, see the 'Search' button? You can always use that or the LabVIEW help.
01-10-2010 08:28 PM
shrek'sdonkey wrote:
Hello what I meantis that how can I play a sound clip in Labview because I do not think that there is a thing related to this option in Labview
There most certainly is. Just open the Example Finder (Help -> Find Examples), and search for "sound". And, as Dennis pointed out, there's a whole palette with sound functions.
01-11-2010 02:07 PM
01-11-2010 02:12 PM
Only if you want to play a sound like you asked.
You could also use ActiveX for something like calling the windows media player, I suppose. That would be a bit more complicated.
01-11-2010 02:13 PM
01-11-2010 02:15 PM
