help: IMAQdx scale image size
HI all,
i'm new in LebVIEW and have a question.
Im using the functions of IMAQdx for a camera (XCD-U100 UXGA black&white).
Is it possible to take images with smaller size? I want to increase the frame-rate.
I can scale the image, after it was taken in max-size (1600 x 1200). But i want the camera to take in custom size, no in max-size. 🙂
I hope someone can help me 🙂
(2,278 Views)
Hi NEOS,
i is possible to change the resolution in NI Measurement&Automation Explorer.
Go to Devices->IMAQdx Devices here you will find your Camera.
On the bottom of the MAX Window you will find Acquisition Attributes. Here you can change the Resolution of the cam.
Did this help?
Regards
Daniel
(2,255 Views)
Hi NEOS,
any new information?
Regards
Daniel
(2,225 Views)
