hi :D !I want to use images of pumps and valves for scada project, but how can I turn these images into objects?please help me !
@Gregory wrote:
@RamonG wrote:
I like the Rectangular Silver LED but it's not a strict boolean type.
What do you mean by that? If you pull it out of the cluster it looks like a boolean to me.
If you create a value property node the type is a variant. I'm guessing this is the result of the "hack".
Message 11 of 13
(129 Views)
Hi Ramon,
Switch the mechanical behaviour to "Switch…" instead of "Latch…". No hack, but expected behaviour!
Then you could also change from control to indicator as it looks like a LED…
Message 12 of 13
(122 Views)
Thanks, I learned something. I should've changed it to indicator.
Message 13 of 13
(115 Views)
