01-19-2011 10:43 AM
I need to solve simultaneous equations with 3 unknowns . Can any body help out on how to go about this? Thanx.
01-19-2011 10:47 AM
You did not specify what kind of equations you have....
Are your equations linear? Check the linear algebra palette and a look at "solve linear equations:. 🙂
01-20-2011 05:49 PM
KDGREAT,
Altenbach makes available a great palette if you are wanting to use linear equations. The linear equations palette is within the mathematics palette in labview which also has a lot of other options for you to use. Those options are located in this link
David A.
01-21-2011 12:46 AM
I'm using student version of LABVIEW. From the inspection of the simultenous equations, they will involve both linear and quadratic. I will like to know the step by step procedure on how to implement the solution. Thanks.
KDGREAT.
01-21-2011 12:53 AM
The equations involve both linear and quadratic. Expecting your suggestions.
Thanks.
01-21-2011 03:26 AM
Ca you give an actual example for the set of equations?
01-21-2011 03:32 PM
Knowing how many of each equation types you will be dealing with will help this discussion further. It is hard to give you more details on the steps you want to accomplish without knowing a little more information.
Back to my first post, the mathematics post is what you want to look at. Two ways to get the implementation you are looking for are:
1. Linear Algebra --> Solve Linear Equations
2. Scripts and Formulas --> Zeroes --> Non Linear System Single Solution / Solver.
David A.
01-22-2011 12:41 AM
Than you all for your reply. There are three set of equations with 3 unknowns. Like I said ,the equation will involve both linear and quadratic. Can I implement this on LABVIEW student version? If yes how?. Hope this throws more light on the topic. Thanks.
01-22-2011 12:49 PM
What makes it so difficult for you to simply show a typical example of a set of equations instead of repeating what you already said? It would really help us understand the problem!
Try again! 🙂
01-24-2011 10:50 AM
the equation is in this form;
4X = 2345 r............................(1
6X + 4V + r = X-20r.................(2
2X + R + V = r + 2 V..............(3
SOLVE FOR r,V and X.
