Several problems with your code:
1... Bad idea to use lights as buttons. Yes it can be done, but it's not "natural".
2... If you've gotta do that, set their mechanical action to "LATCH WHEN RELEASED"
3... Because of #2, you are getting TWO copies of every array when you click the LOAD VIs light (er... button).
4... No need for the conversion from path to string and back - use BUILD PATH to append each file name to he folder path.
5... Set the BROWSE OPTIONS on your PATH control to EXISTING DIRECTORY to allow browsing of directories, not files.
6... Your code doesn't care whether the file is a .VI file, or a .ZIP file, or a .TXT file, or what. Use the PATTERN input on the LIST function to discriminate.
7... Your code is only storing the latest refer
ence, not the array of references.
8... An ERROR DIALOG on the OPEN REFERENCE function will tell you that you're getting an error. Why? You are asking to prepare a non-reentrant VI for reentrant execution (why use options = 8?)
9... Because of #8, the latest VI reference is invalid.
