how to able or disable a string controll
Hello everyone, I wanted to know how I can do to enable or disable writing in a string controll with a boolean button.
(1,234 Views)
You can use a "disabled" property node for the string.
(We can give more specific advice once we see your code)
(1,213 Views)
A Select function will also be needed to chose to write the enabled property to "Enabled<0>" when the boolean is set to enable the string control and "Disabled<1>" or "Disabled and Greyed<2>" when the boolean is in the other state.
"Should be" isn't "Is" -Jay
(1,210 Views)
You find attached a VI that contains a solution for your problem.
Best Regards.
(1,177 Views)
Some quick comments:
  • If all cases of a case structure contain the same property node, that node belongs after the case structure. No need for al that code duplication.
  • As has been mentioned elsewhere, a select node would be cleaner unless the cases also contain additional code. It is easier to edit and debug code if we don't need to constantly flip through cases
  • It seems convoluted to use the event data node output if the control sits right there..
  • There needs to be a way to define the state when the program starts, i.e. before the user presses the enable/disable button. One possibility would be to add a timeout to the same event that zero once, then infinite. (see image)
  • "Disabled" and "Disabled and grayed out" are not the same and the OP needs to decide what's more appropriate. So far only "Disabled" was mentioned.
(1,156 Views)
