how to add silver front panel theme for labview 2010
(2,978 Views)
I haven't try but it's worth spending a few minutes on it, I would create the CTL in LV2011 SP1 and une the "save for previous version".
Booh fail :
Would have been too easy 😞
Epictetus
Antoine Chalons
(2,976 Views)
yes i had tried this way but the vi built with silver theme doesnt look good in 2010 😞
wish if there was a way to include silver theme in 2010
(2,957 Views)
The only way I see to make it like that would be to recreate the theme in LabVIEW 2010 with external bitmap objects. Unfortunately it won't be as functional as the silver controls in various terms such scaling (bitmaps scale very badly) or transparency and click through functionality (a bitmap assigned to a control part will always catch all clicks and never allow a click to pass through anywhere to a lower layered part).
The silver controls are using special internal graphic objects that were added in LabVIEW 2011, so recreating silver controls with the same functionality in earlier LabVIEW versions is impossible.
Rolf Kalbermatter
My Blog
(2,950 Views)
Adding to Rolf's comments, if you do decide to go down that path. Look at the powerpoint decorations video in this link: https://decibel.ni.com/content/groups/ui/blog/2010/04/29/creating-quality-uis-with-ni-labview--devel...
Not completely related, but this could be potentially useful.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,938 Views)
