how to center row name in muliti list box
I want to add name for row and column. But it cannot be displayed in center automatically.
any property can be used for that?
please see my picture.
Thanks.
Anyone can give me some example about multi list? I want to study it.
THanks.
(3,200 Views)
double click to select the text then use the font dialog to set your justifiaction to be "Center" Repeat for the other fields. There should also be a  property for the text to let you set this programatically.
Ben
(3,195 Views)
Using Property node
Message Edited by muks on 07-31-2009 05:18 PM
(3,174 Views)
Please do it like this. If you select "cell justify" alone then the property will be set only for the first element. active cell is like a pointer. Change it dynamically using a loop.
(3,166 Views)
Accepted by topic author mmm2006
Thank you very much. It is very help for me.
(3,146 Views)
