how to change names of an Boolean array in a which has been placed in a cluster?
Hi guys,
for my program i need to initialize which tests are in a testblock. Each test is settable with a Booelan button to enable the test, or disable it.
I have actually 22 testblocks containg over 400 tests. What i would like to do is to make 1 array  with Boolean buttons. So, if you're exploring the testblocks, the labels of this buttons must contain the test names. How can i make a program so the testnames will be automatically transferred to the label of the Boolean buttons? (My array of buttons is placed in a cluster, because i have more data to store about the tests..)
thanx for your help.
(3,105 Views)
Hi btwesseli...,
in an array all elements have the same properties. So you cannot make the labels/captions or whatever different for those booleans.
But:
You can overlay an string over the boolean button. Make a string indicator your cluster, make this string transparent and move it over the boolean. Now you can have a
'label' over the boolean containing the name of the test.
(3,095 Views)
Ok thanx! It is worth a try!
By the way, is it possible to change one individual value in the array? for example, if I want to change button 1 to true, how can ii do that programmatically? It didn't work out that well with a property node...
(3,091 Views)
Hi btwesseli,
it's LabView, so you better use dataflow programming 🙂
To change an array element use the function 'Replace Array element'. If you do this in a loop you should use shift registers to keep the latest version of your array.
(3,059 Views)
