how to convert a baseband signal with bandwidth 20MHz to an RF signal with center frequency 2.4GHz and the same bandwidth 20MHz
        I was wondering how to convert a complex baseband signal with bandwidth 20MHz to an RF signal with center frequency 2.4GHz and the same bandwidth 20MHz in simulation. I tried
    1. Multiplying the complex double type baseband signal (1-D array) by exp( j * 2 * pi * 2.4E+9 * T ) where T is the symbol period of baseband signal.
    2. Usage of MT upconvert baseband but doesnt keep the BW constant
Looking forward to your help.
(3,655 Views)
in the time domain this task is typically done be multiplication with a carrier (2.4 GHz). However, what you get is carrier + baseband and carrier - baseband. So you get double bandwidth and must filter one of the sidebands.
Cheers
Edgar
(3,650 Views)
I should add that you can multiply your baseband signal with two carrier signals that are shifted by 90° and then add or subtract the result to obtain upper or lower sideband only. You can try to search about IQ moduilators/demodulators to learn more.
Cheers
Edgar
(3,642 Views)
