how to create a linux shared library in c language to use with labview
Can someone please tell me how can I create a linux shared library, to use in labview?
I will be creating 3 shared libraries, 1 for serial communication, 1 for battery status, and the last one, to detect the computers power changes, such as shutdown, restart, hibernate,sleep, logoff.
Please give me some information, so I can start coding.
Thanks.
Message 1 of 9
(3,378 Views)
What are you planning to use to create the shared libraries? LabVIEW or some other programming language?
Message 2 of 9
(3,364 Views)
I'm trying to make these shared libraries in c/c++.
Message 3 of 9
(3,357 Views)
Then you are posting to the wrong place.
Message 4 of 9
(3,348 Views)
where should I post?
Message 5 of 9
(3,343 Views)
To a Linux board. That would seem pretty obvious to me.
Message 6 of 9
(3,337 Views)
thanks.
Message 7 of 9
(3,334 Views)
Outside of actually making the code you want to call, there is integrating it into LabVIEW. For that you'll want to start here:
https://decibel.ni.com/content/docs/DOC-9076
Message 8 of 9
(3,325 Views)
Once your libraries are built, here's a discussion thread that may help you when calling the libraries.
https://forums.ni.com/t5/LabVIEW/Programming-a-c-application-which-is-calling-a-so-built-by/m-p/3087...
Michel
Message 9 of 9
(3,287 Views)
