how to do fast fourier transform of a 50Hz motor
hi
i've been monitoring performance of a 50Hz induction motor. I have to monitor its instantaneous supply voltage and frequency spectrum.
i'm using data acquisition card PCI 6025E and CB 50LP as my input board.
i'm an amateur in using labview. i'm giving my input to pin 5. the output voltage levels are shown correctly on the labview software but i dont know how to do fourier analysis on this signal.
So please if anyone can help me with this?
Danish
Message 1 of 22
(3,944 Views)
Well, any "instantaneous" function has all frequencies, you need to decide on a realistic sampling interval for the FFT. At least a couple of cycles of your primary frequency.
What are you interested in? (Main frequency, magnitude spectrum, harmonics, phase, etc.)
Have a look at the shipping examples and help. Maybe windowed_fft_ptbypt could be useful?
Message 2 of 22
(3,940 Views)
i'm interested in a  graph of magnitude vs. frequency. i tried it real fft
as the frequency of my input signal is 50Hz, i reckon that the magnitude should be maximum at 50 hz. but its not coming that way.
What should i do??
Message 3 of 22
(3,937 Views)
Drizvi,
1. The standard FFT VI does not know anything about the actual frequencies because it has no data about the sample timing.  Did you calculate the frequency of the peak(s) correctly from dt or fs and N?
2. Usually currents tell more about the behavior of a motor than the voltage.  The voltage waveform is strongly affected by the impedance of the power line feeding the motor and the user may not have any good way of measuring that.
3. Please post your entire VI with some typical data saved as default so the we can see what you have tried.  Also includes some notes about what is not working and what you expect to see.
Lynn
Message 4 of 22
(3,922 Views)
Message 5 of 22
(3,903 Views)
That's not a block diagram, just a picture of one. For better help, I recommend you attach the actual VI instead 🙂
Message 6 of 22
(3,900 Views)
view of the two graphs at a particular instant is found to be as follows... note that the voltage levels shown are correct and the frequency is also 50Hz.16-6-1.png
changing the rate and number of samples per channel effects my frequency spectrum also along with the Voltage vs. Time graph!!... is this because of the wrong values that i'm not getting the right frequency spectrum graph(peak at 50 hz)??
the actual picture that i should get should look similar to this one:- a peak at 50 hz-the required result.png
Message 7 of 22
(3,899 Views)
these are the statistical results of the two graphs which i saved in spreadsheet form
frequency - Dev1/ai1 Power - Dev1/ai1   Time - Dev1/ai1 Voltage - Dev1/ai1
0 1.29883   0 -2.22168
1 2.09414   0.001 -4.21875
2 1.13731   0.002 -5.32715
3 5.43666   0.003 -5.58594
4 5.82516   0.004 -5.38574
5 -30.983   0.005 -5.48828
6 1.41211   0.006 -5.06348
7 7.42809   0.007 -3.50098
8 -2.53653   0.008 -1.61133
9 -0.909421   0.009 0.092773
10 3.42202   0.01 1.85059
11 1.55612   0.011 3.62793
12 1.80721   0.012 5.11719
13 0.889882   0.013 5.63965
14 2.6722   0.014 5.53223
15 -3.30237   0.015 5.71289
16 0.447473   0.016 5.06348
17 4.00947   0.017 3.76465
18 -0.0827129   0.018 1.94824
19 1.02037   0.019 0.375977
20 -0.779498   0.02 -1.25977
21 -0.137275   0.021 -3.10059
22 -1.02245   0.022 -4.81445
23 1.707   0.023 -5.58105
24 -0.926762   0.024 -5.56641
25 5.74219   0.025 -5.81055
Message 8 of 22
(3,897 Views)
data continued.....
26 2.13652   0.026 -5.43457
27 2.68125   0.027 -4.27734
28 1.56023   0.028 -2.64648
29 1.23211   0.029 -1.08398
30 1.58775   0.03 0.732422
31 1.50831   0.031 2.86621
32 1.47299   0.032 4.74121
33 1.36161   0.033 5.64453
34 1.6734   0.034 5.69336
35 0.831643   0.035 5.77148
36 0.946556   0.036 5.41992
37 0.362077   0.037 4.63379
38 1.37709   0.038 2.91504
39 0.9127   0.039 0.986328
40 1.5461   0.04 -0.9668
41 1.79433   0.041 -2.9834
42 1.5145   0.042 -4.73633
43 1.57445   0.043 -5.49316
44 0.833135   0.044 -5.49805
45 1.27115   0.045 -5.4248
46 2.42666   0.046 -5.37598
47 1.40348   0.047 -4.57031
48 1.30052   0.048 -2.85156
49 1.62348   0.049 -1.01074
50 1.45508   0.05 0.820312
51 1.62348   0.051 2.53418
52 1.30052   0.052 4.34082
53 1.40348   0.053 5.29785
54 2.42666   0.054 5.60547
55 1.27115   0.055 5.4834
56 0.833135   0.056 5.43945
57 1.57445   0.057 4.60938
58 1.5145   0.058 3.06641
59 1.79433   0.059 1.40137
60 1.5461   0.06 -0.23438
Message 9 of 22
(3,896 Views)
oh sure sir!!
Message 10 of 22
(3,894 Views)
