how to give a name to my table so that when exported to excel automaticaly it wille has the same name in excel
Hello
Please, I use the vi attached to transfer Table 2 D (indicator) of labview to excel but I get as column names (column 1, column2 ..)
how  can i change these column names or just how to name my table way that it has a name automatically in Excel?
Message 1 of 12
(3,920 Views)
      Get the row and column header value using the property node and build it to obatain the required output format.
Refer to the below snippet and connect the expected array output to your vi and it will work fine .Hope this helps 🙂
Kudos Welcome 🙂
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
Message 2 of 12
(3,910 Views)
Ok but how can i enter the name of columns?
Message 3 of 12
(3,892 Views)
can you share a sample of data that you want. also attach the sub vi so that it will be easy to address the issue.
Message 4 of 12
(3,888 Views)
Here is it 🙂 sor example i can name its columns (intensite 1,intensite2...)
Message 5 of 12
(3,883 Views)
I  just want to give a title to the excel table
Message 6 of 12
(3,869 Views)
oh ok i understood. you want to give the tittle at the top and then followed by the content inside the table in a xl ...
is the below image is your required output???
Message 7 of 12
(3,866 Views)
You didn't attach mm.vi which is the important part. Also attach an example of what is your ecpected results in Excel.
Ben64
Message 8 of 12
(3,854 Views)
C'mon people, are we really doing this (what is clearly a) class assignment for Maroua?  "Show how to write table data in an Excel Worksheet"?  At least the assignment makes it clear we are talking about Windows with Microsoft Excel.
Maroua -- there are examples that come with LabVIEW!  There are examples within the Forum!  Show us that you are at least making a token effort to do your own work ...
Message 9 of 12
(3,844 Views)
Yes Exactly 🙂
Message 10 of 12
(3,797 Views)
