how to link third party software with labview program ?
I have designed a labview
program to analyse and make
graph and save the datas
from the photon counter using
ni USB DAQ 6008. And the
photon counter is controlled
by the third party software with
itself. both programs are
executing successfully. But
my task is run both the
program at the same time. i.e.
link the third party software
with my labview program.
How to i do this?
(4,013 Views)
Turn your labview coding into DLL.
http://zone.ni.com/devzone/cda/tut/p/id/3517
Then use your third party software to refer to the DLL.
(4,002 Views)
Your question is too vague since you give no information as to this third party application. Is it an application you wrote? Is it an application that you cannot change? Does it have a programming interface? Can you eliminate this third-party application and control the photon counter yourself? Have you tried to do a search, as this question has come up before many times. For example:
http://forums.ni.com/t5/LabVIEW/how-do-I-use-labview-to-control-other-programs/m-p/424765
http://forums.ni.com/t5/LabVIEW/How-to-operate-another-application-s-GUI-from-LV/m-p/668088
(3,986 Views)
The third party software does not change my me. It is only for initialize the spectrometer and photon counter. And also it is a software coming with spectrometer by their manufacturer itself.
(3,973 Views)
(3,972 Views)
If it has a GUI, use autoit to interact with it and call it from LabVIEW. Autoit has a lot of features to interface and automate GUI's without modifying them. It has a little bit of a learning curve, but it is very useful for this purpose. Plus its free.
(3,960 Views)
You can also use the operating system API. On Windows you can use SendKey. In terms of using SendKey, search the forum and you'll find examples. Such as this one. In terms of AutoIt, I have used this before. You can search the forum to find examples for this as well. Such as this one.
(3,952 Views)
