how to pass my input parameters (duty and frequency) to other loop?
Hi everyone..
Can you help me in doing my project..I have a problem regarding passing my two parameters (duty and frequency)
from my main while loop passed to PWM program (other while loop).
As for your reference, attached with my VI project.
Hope to read your response guys!
thanks and regards,
Ludz
(2,584 Views)
          To be honest , i didnt open your example and check it. But as far as passing arguements from a while loop, if you are planely wiring the parameters it will wait for the while loop execution completion. So to avoid it you can just make two references for both of your parameters and place it outside your first while loop and then pass it to the second while loop. Hope it works..
Best Regards,
Nitzy
(kudos are always welcome for good suggestions)
(2,575 Views)
See the attached VI and tell me the result..
(2,568 Views)
Hey guys,
Thanks for your reply.
Nitzy,
I will try your suggestion.
Kaush,
I Can't open your attached file.
regards,
Ludz
(2,527 Views)
You will need the following application to unzip the file:
http://www.7-zip.org/
Flash P
(2,495 Views)
