09-07-2012 03:58 PM
Input can be 3000, 3e+3, or 3k (SI).
How to prohibite input in SI notation, for example "3k"?
Thanks, Andrey.
09-07-2012 04:00 PM
I'm not sure I entirely understand the question. Are you saying you don't want a user to be able to enter "3K" into a numeric control instead of "3000"? Curious: why?
09-07-2012 05:29 PM
actually, this is customer's question.
he wants to avoid situation when user make mistake like getting "3000" (="3k") instead of "30"
09-07-2012 06:16 PM - edited 09-07-2012 06:18 PM
My first choice would be to simply use the Data Range to prevent out of range values regardless of how they are input. If you really want to filter the allowed keys you need to use an Event Structure. Here is an example, the string contains the allowed ascii characters, a separate case also allows Enter, Return and Delete, all other keys are blocked. In the Disabled Case of the Diagram Disable Structure is simply a constant lookup table since you really only need to calculate it once unless something changes.
Of course a fiendishly clever person could always paste an SI value in there. (Why I would also rely on Data Range)
