how to simulate buck,boost and buckboos converter
has anydone tried simulating this circuit?i need some pointers..Smiley SadSmiley Sad
Message 1 of 9
(5,375 Views)
Hi neerza,
What, exactly, are you trying to do?  What is your application?  What software are you using?  (If LabVIEW, what version and with what toolkits/modules?)
If you are simply trying to simulate a circuit, you may want to take a look at NI Multisim.
Message Edited by Eric_V on 03-07-2008 01:52 PM
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 2 of 9
(5,337 Views)
dear sir.i'm using labview 7.1.its basic packages.my lecturer said that i need to build the simulation using functions available in labview.using equations to produce waveforms of the converters but i have no idea in doing that.
Message 3 of 9
(5,325 Views)
Hi neerza,
It sounds like you know what you want to do, you just need to learn some LabVIEW fundamentals.
I recommend you look at the six hour tutorial for LabVIEW .  Also, I think a MathScript node may be a good choice for coding an algorithm to perform this kind of simulation.
Eric V
Message 4 of 9
(5,293 Views)
sir,what is mathscript?i dont know bcoz its not in my sylibus.it is the same with matlab?
Message Edited by neerza on 03-10-2008 08:15 PM
Message 5 of 9
(5,285 Views)
Mathscript is similar to Matlab. in that you can directly type some valid algorithm inside the Mathscript node, that ll get executed as per it.
It is integrated inside LV itself.
But, I think, it is available only from LabVIEW 8.x & above...
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 9
(5,277 Views)
parthabe is correct;  I'm sorry I forgot you were using an earlier version of LabVIEW.
You will need to implement your logic in the LabVIEW block diagram yourself;  you do have the much more limited Formula Node available to you in LabVIEW 7.
Eric V
Message 7 of 9
(5,255 Views)
means that i need to use the formula node to simulate the circuits of the converters is it?
Message 8 of 9
(5,251 Views)
Yes.
Message 9 of 9
(5,243 Views)
