07-12-2005 03:57 AM
07-12-2005 05:19 AM
Hi Kel,
I know a little bit the SMU's from KEITHLEY - but unfortunately not the one you mentioned..........
Find some hints about the 6430 @: http://torque.oncloud8.com/archives/cat_keithley_6430.html
Hope this helps
Werner
07-13-2005 01:33 AM
Thanks for the reply.
The URL didn't help much.
What i basically would like to do is to
source a fixed voltage and measure the corresponding current.
AND source a fixed current and measure the corresponding voltage.
Currently, my program uses SMU236 to do that but i would like to change it to 6430 because it has a bigger range but i'm unable to do so.
07-13-2005 02:57 PM
Hi Kel:
It looks like the only drivers available for this instrument were written by Keithley. I downloaded them and it really just looks like GPIB code. Unfortunately since I'm not familiar with the instrument itself and don't know the commands I'm afraid I will be of little to no help here. I would recommend that you contact Keithley for support as they will know a lot more about these particular drivers.
Emilie S.
07-13-2005 09:00 PM
07-14-2005 05:21 PM
07-18-2005 01:26 AM - edited 07-18-2005 01:26 AM
Message Edited by kel on 07-18-2005 01:43 AM
07-18-2005 07:18 PM
07-18-2005 08:14 PM
05-22-2009 07:28 AM
Hi! i need to do a IHM with the Keithley 6430 and i have to use the port GPIB but the national instruments doesn't provide the drivers , so i was trying with the drivers that i found in the Keithley on the internet but it doesn't work. there is a error in the initialize.vi and the code is number 6 but i don't have any idea that it means.
if you have any advice...i would really appreciate it.
