08-03-2023 04:13 AM
labview 可以将csv文件格式转存excel格式吗,目前想用labview在csv文件里增加一列数据,用csv格式处理好麻烦,有遇到过类似的问题的吗
08-03-2023 04:32 AM
@留白 wrote:
Can labview transfer the csv file format to excel format? Currently, I want to use labview to add a column of data in the csv file. It is troublesome to use the csv format. Have you encountered similar problems?
What's "troublesome" to read a CSV file, add a column and then save the updated data to a CSV file?
08-03-2023 08:04 PM
你的意思是先将csv文件格式保存为excel格式,然后进行数据处理吗
