12-02-2018 06:05 AM - edited 12-02-2018 06:06 AM
Hi, wen im run the vi it clos immediactly and it give me this error
"labview Access violation (0xC0000005) at EIP=0x05CD4BBC"
i have try t reinstall imaq - vision assiant - vision aquisition
but the prolem isn't solved..
another problem is the vision assiant whan don't open
I hope I do not have to solve formatting, because this problem was not there a short time ago
Solved! Go to Solution.
12-02-2018 10:04 PM
How do you exit the application?
You are connecting "FALSE" constant to While loop stop condition so,
I guess you use "Abort" button.
If so, no memory is freed correctly and the crash would be.
Use Stop button.
12-03-2018 08:50 AM - edited 12-03-2018 09:13 AM
Ok the strutture of the vi isnt corretti, but I think the problem of crash is the vision acquisition, and imaq file.. i tryed to reinstall but the problema isnt solvend.
Pls help me, of i dont solved the last solution is format windows
12-04-2018 03:38 AM
for those of you who have the same problem:
I have uninstalled labview with all the expansions, and then reinstall it.
the crash is solved
