labview and amcharts
my English is bad
sorry
there is an icon called Measurement write to file, but i do not know how use it
tdm nose generates files but if this file can be converted to xml
if you realize if you can see the code in xml, but apparently is not as xml files that have amCharts
I am an engineer in electronics and computer do not know much
here leave the amcharts file
Message 21 of 30
(2,171 Views)
You are not generating the XML file in the format that's required. You can't just give it an arbitrary format. The web site clearly documents the format of the XML file. The examples also have several XML files that you can look at to see the format. Is there a particular reason why you want to generate XML? Why don't you just generate the "CSV" format, which can be done quite easily.
Did you actually write that VI, or did you get it from someplace else? It looks like an example VI, though I'm not sure which one.
Message 22 of 30
(2,170 Views)
there is no special reason for using xml
yes is a example from labview
if you can help me to create a VI  where  make a csv file
for example, a VI where we can move a knob and that these values are stored in a csv file
you have been very kind, thanks
Message 23 of 30
(2,165 Views)
Attached is a simple example that generates a delimited text file, along with a web page that holds the amChart control. Note:the web page loads the control from the "amline" folder that resides in the same directory as the web page. That amline folder is the same folder as what you get with the downloads from amcharts.com. The path to the control is specified in the HTML code for the web page.
Message 24 of 30
(2,136 Views)
grand
I test the file and let you comment as I run
thanks
Message 25 of 30
(2,131 Views)
you worked?
because I run the program and open the page "index" and I get the bottom of the graph but not the data, ie it seems that I get the template but the data graph
no data graphs
Message 26 of 30
(2,126 Views)
are the x-axis values
but do not appear axis values and
it happen?
Message 27 of 30
(2,123 Views)
yeah, is working !!!!
only is  modify in labview %.0f
because if you not modify this parameter not work
i put h how separator but you can leave same form
the image of plots it's here
Now I just need to detect the variations of the knob when moving, bone precione not have to "add" or press "save"
Message 28 of 30
(2,104 Views)
Accepted by topic author covenan
The VI as I had posted generated a data file that was loaded into amCharts correctly. It appears based on your picture that your decimal point is a comma instead of a period, which is what is used in the US.
I don't quite understand your last sentence. Are you asking another question there? Can you say that differently?  Try posting in your native language. Perhaps someone can translate, or we can try Google Translate.
Message 29 of 30
(2,090 Views)
spanish:
si es otra pregunta, lo que pasa es que quiero hacer que el programa siempre este grabando los datos y que en lugar de precionar el boton "add" se guarde automaticamente.
english:
Yes is other question.
i try do the following
i try make a program that don't waiting that  press the botton "add"  for save the data measurement
and try  do a program that  save continuously, not need press the botton save.
you can help me?
thanks
en español: Muchas gracias
in english: thanks very much
Message 30 of 30
(2,069 Views)
