02-19-2020 10:35 AM
Dear Forum Members,
I am developing signal generation and acquisition application using parallel loops and NIDAQ hardware. I thought it would be good if I use an example from Labview (continuous measurement and logging using NIDAQmx) as a template where some useful lvlibs are provided for acquisition, logging to disk etc. However are there any similar lvlibs, but for signal generation? I cannot find anything, but maybe I'm missing something.
If not I'm happy to develop something similar by myself or modify existing subvis from this example, but thought I would save some time if there are any templates for generation.
Many thanks,
Piotr Golacki
02-19-2020 12:58 PM
There are multiple NI Examples for "signal generation" -- they are called "Analog Output", "Digital Output", or "Counter Output" (depending on whether you want to generate an analog, a digital, or a pulse train signal). Open LabVIEW, go to Help, Find Examples, and in the Example Finder, look under Hardware Input and Output, DAQmx.
02-20-2020 08:11 AM
Dear Bob,
Thank you for your reply.
I looked through the examples. However what I was looking for was a template similar to Continuous Measurement and logging (NI DAQmx) which is based on QMH and has some neat lvlibs, I was hoping for a similar template for signal generation.
Also is there any other way to add those ready lvlibs shipped with LV templates? I hoped that maybe there is a library of those lvlibs and maybe there is something more there. I tried to find them, but it doesn't seem that they are available in any other way than by starting with a template. Which means I need to create my own counterparts, which is OK. But if someone can prove me wrong that would be great.
Many thanks,
Piotr Golacki
02-20-2020 10:42 AM
If you search through the LabVIEW directory (in Program Files etc) you should find the code that generates the template.
I'm on a phone currently so I can't find the path, but I'd suggest looking at either the resources folder or maybe examples (that might be a subdirectory of another, maybe VI.lib?)
I'll check and post again tomorrow if you're still looking in 8 hours or so.
